:D Non non, ça doit faire 20 ans que j'avais Wang-Po, payé pas bien cher en francs (voire en francs CFA) à l'époque mais quand il faut faire deux tours de vis pour que ça commence à bouger, c'est qu'il y a un souci quelque part Reprenons... Après vive discussion sur le forum Cadillac US, j'ai le fin mot de l'affaire... je vous le livre en VO pour mieux apprécier Removal and Installation of Rear Axle Pinion Oil Seal – 1937 to 1952 1. Drain oil from the rear axle. 2. Remove both rear wheels and brake drums. This is to eliminate brake drag when measuring the preload torque on the pinion bearings. As an alternate, back off on the brake adjustment to eliminate all drag. 3. Disconnect rear universal joint and optionally remove front so entire drive shaft can be removed. This is to get it out of the way for work to come. 4. Using a socket and adapters to go from the nut holding the yoke to a 50 inch-lb. (repeat inch-lb) torque wrench measure the resistance of the pinion shaft to rotation. Do not count the initial load to start the motion. One expects to see a reading of 10 to 20 inch-lbs. Note this value. 5. Mark the yoke location on the pinion shaft with a punch so it can be installed in the original location. 6. The yoke nut is staked. Remove as much of the stake as possible. As the nut is removed the staking will damage the threads of the nut. 7. Remove nut with an impact wrench. Use a 7/8 – 14 UNF tap to clean up the threads in the nut. It is important to have clean threads so a proper torque reading can be obtained later. 8. Remove yoke. To remove the seal first tap the seal toward the rear in the seal retainer (size adapter). This will expose a lip on the retainer that a typical slide hammer can catch. Using the slide hammer remove the seal retainer with seal. On the bench carefully remove the old seal from the retainer. 9. In a running change mid year in 1952 Cadillac eliminated the seal retainer design and used a seal with the same ID as the early seals and the same OD as the seal retainer. Due to the relationship of the seal housing to shaft these will not fit on pre 1953 cars even though all of the diameters are correct. 10. Remove washer and tapered roller bearing. 11. Remove the collapsible sleeve using a small needle nose pliers. If the sleeve does not readily come out work the sleeve back and forth with the fingers while at the same time pulling with the needle nose pliers. Note the bulge on the rear end of the sleeve. 12. Using a thread file remove the stake marks from the pinion shaft. 13. In 1939 Cadillac started to use the collapsible sleeve design. For 1937 and 1938 cars see step 21. The purpose was to provide the factory with a simple method to preload the pinion tapered roller bearings. The preload in force is approximately 1200 to 1400 pounds. This force is provided by the designed deformation of a precisely machined collapsible sleeve. This results in the bulge noted in step 11. The risk on disassemble is that the sleeve will now be slightly short which will excessively load the bearings before the yoke nut is tight enough. On reassembly shims can be added to insure that this does not happen. 14. Typically, add a .005-inch or .010-inch shim on the pinion shaft between the sleeve and the rear bearing. This shim is 2.375” O.D. and 1.875” I.D. It is available as a shim pack for a Dana D44 30 spline rear end. This is available from Randy’s Ring and Pinion, 800-347-1188 as part number SK 30214. This may also be available at other sources. 15. Using emery cloth clean the inside of the sleeve to insure that it can be installed and removed easily. Oil the sleeve on the ID and after adding the shims reinstall the sleeve, bearing and washer. 16. At this time do not install the new seal but trial fit the yoke, washer and nut. Tighten the nut snuggly and check to see that approximately 0.010 inch of endplay exists in the pinion shaft bearing assembly. If not, disassemble and add or subtract shims. This endplay will be removed when the nut is tightened and the sleeve collapses further. 17. Remove the yoke one final time. Install the new seal in the retainer and install the complete seal assemble in the differential housing. A modern seal (National #473179, NAPA #18671, or equivalent) made with a single sealing surface is recommended over the original leather type. Install the yoke (aligned with previous mark on pinion splines). Before installing the yoke clean the seal surface with 400 grit wet and dry sand paper. If seal surface is damaged in any way use a speed-i-sleeve to repair (part # 99187). 18. Install the yoke and tighten the nut to snug and confirm again that endplay exists in the pinion shaft. The sleeve will now need to be collapsed further to eliminate the endplay. Tighten the nut to at least 225 ft-lbs. and measure the inch-lbs drag on the bearings. It should be roughly the same as before disassemble but if 10 inch-lbs are achieved with used bearings and the nut is tightened to at least 225 ft-lbs the job is done. Tool J-2659 is used to hold the yoke while torque is applied to the nut. If tool is unavailable, something needs to be adapted. If drag is low tighten the nut one-half flat at a time beyond 225 ft-lbs and recheck drag. Continue until drag is correct. 19. Stake pinion nut. 20. Refill axle with oil and reinstall brake drums and wheels. En rouge, des trucs qui ne sont pas dans le shop manual et qui peuvent expliquer mon souci. L'explication par l'image (flèches vertes) : Ceux qui ont lu jusqu'au bout peuvent rire bien fort... En espérant que ça puisse être utile à certain(s) possesseur(s) de Cadillac 1951-52 du forum
C'est vrai que cette voiture revient de loin... cette litanie de petits problèmes qui se sont transformés en défis, ça en fait des choses à raconter bravo pour cette renaissance
Sympas les photos étonnant d'en voir autant rassemblées alors que j'ai dû en voir une de toute ma vie Je n'avais jamais entendu parler de ce club (ton club ?) d'anciennes.
Le certificat de vente allemand sera à ton nom, ou au nom de celui qui te la vend ? Dans le deuxième cas, ça va être beauuuuuucoup plus compliqué .
J'en profite pour vous présenter mon nouveau pensionnaire Nestor, un antique étau (à lire vite à haute voix ) récupéré dans un local que j'ai vendu il y a quelque temps. ça fait une quinzaine d'années que je l'ai, mais je ne l'avais jamais monté. Embarqué ce matin au TBird's garage, où je l'avais laissé à la poussiére et aux toiles d'araignées. Une centaine de grammes de bonne graisse aux endroits stratégiques, et hop Il remplace mon valeureux Wang-Po (un Chinois ), dont la fonte de véritable tôle ferraillée à Detroit et à Levallois-Perret a fini par déclarer forfait après un coup de massette de trop...
Belle trouvaille Elle a un pédalier "normal" (avec pédales à l'emplacement habituel) ? La Ford T avait un agencement bizarre, avec (je crois) l'accélérateur au milieu, ce qui doit surprendre en freinage d'urgence
Merci mon Ricky Bon, j'ai décidé de remonter sur ce pont tout ce qui y est attaché (freins etc) avant de remettre l'ensemble sur (ou plutôt sous) la voiture. Pourquoi ? Parce que la voiture est à 20 min de chez moi et que j'ai rarement plus d'une heure ou deux devant moi, donc je préfère garder le pont à la maison et je bosse dessus à mon rythme. J'avais changé le spi d'arbre D fuyard il y a 5 ou 6 ans. Il y a même eu un sujet sur le forum, avec les dégâts causés par mon insistance à rentrer à la maison : roulement explosé, freins couverts d'huile, arbre de roue à changer... bref, je change en préventif le spi G (qui a le même âge), avant qu'il me fasse le même film On le positionne à sa place avec une dose de joint silicone pour pas que ça fuie par la périphérie. Ladite périphérie est recouverte d'une sorte de plastique souple pour ça, mais le logement est plutôt saccagé, donc soyons prévoyant . (noter l'emplacement du roulement bien deg', ça sera nettoyé après) Puis on tapote à la massette avec une douille "camion" qui va bien.... ... je suis maudit Bon, cette fois il y a la place au milieu. Avec quelques chutes de fil de cuivre en 4 mm² repliés en crochets, ce ##### ressort a fini par reprendre sa place Ensuite, on place de chaque côté les vis de fixation et un joint papier neuf (pour isoler les freins de la poussière ou de l'eau de la route ? ) Puis les flasques de freins, et les arbres de roues après avoir tartiné d'huile le spi et les cannelures : Attention, les flasques G/D sont différents à cause du système de frein à main. Les arbres sont également différents mais ça se voit de suite (longueurs différentes ). On note l'ordre de montage (de droite à gauche) : joint, flasque, bague de roulement, roulement, plaque de maintien, moyeu. Les boulons de montage ont une tête de forme spéciale. Noter aussi, en partie basse, la petite tôle déflectrice d'huile, qui évite de tout arroser en cas de fuite. (d'ailleurs, je ne retrouve qu'une de ces deux tôles, va falloir que je retourne quand même au TBird's Garage ) L'ensemble monté, il restera à poser toute la quincaillerie des freins, et à fermer avec le tambour
Numéros frappés sur la culasse droite et/ou au-dessus du filtre à huile, numéro de fonderie sur le haut du bloc à l'arrière (près de la fixation de boîte)... bref, tout ce que tu peux voir tant que le moteur est sorti
Pas plutôt 3970010 ? c'est l'un des castings les plus répandus, il faut d'autres numéros pour préciser.
[RESOLU] L'essence qui n'arrivait pas au carbu...
Phil a répondu au sujet de EiGhT-PaCk dans Mécanique Générale
Le "sender" c'est la sonde (la jauge, c'est l'aiguille au tableau de bord).. Une crépine bouchée par des saletés, ou un tuyau percé au-dessus de la crépine et qui pompe de l'air. Sinon, une sonde montée de travers, avec une crépine qui ne descend pas au fond du réservoir. Si le test avec le tuyau au fond d'un bidon ne donne rien, il faut chercher du côté de la pompe. Pompe HS, ou (plus chiant) excentrique d'AAC bouffé. Tu peux aussi tester avec une poire d'amorçage en caoutchouc. -
Les Edelbrock sont fabriqués par Weber. Ce sont d'ailleurs des Carter AFB rebadgés . Pas de numéros frappés sur les blocs Ford, et les numéros de fonderie sont cachés derrière le démarreur, là où personne ne peut les voir sans tout démonter En plus, ils donnent beaucoup moins d'infos que les numéros de culasses Ici c'est clairement un 351 Cleveland. Il y a un "2" ou un "4" (et pas un "6") sur le coin extérieur avant de chaque culasse. Le "4" désigne un mythique 351-4V, bien connu des amateurs de drag pour sa capacité à prendre des tours. Et aussi ses problèmes chroniques de lubrification quand on veut lui faire prendre un peu trop de tours . La puissance maxi dépendant directement du régime maxi, difficile à dire. ça dépend surtout des risques que tu es prêt à prendre pour dire sans mentir que tu as 300 ch et pas 250. De toute façon, à ces régimes en boîte auto, le Ranchero a largement passé les 180 km/h, et le papier rose prend autant de risques que les coussinets de bielles...
Photos des cache-culbus, collecteur, carbu, et éventuellement coin de culasse où il y a un "2" ou un "4" dans la fonderie Le cache sert une fois sur un million, quand un gravillon ou un vieux clou qui veut taper dedans ne le trouve pas... il trouve alors tout un tas de trucs intéressants, comme les dents du flexplate ou la tôle du convertisseur qui l'emmènent faire un tour de manège.
Sur les 351 et surtout ces années-là, le fait que ce soit un Cleveland ou un Windsor, et le carbu un 2 corps ou 4 corps (avec le collecteur adapté) peut changer énormément la donne. Photos photos... Sinon, oui tous les moteurs Ford étaient peints en "Ford corporate blue" .
Si tu mets un 25A, que tu roules de nuit, et que pour tourner tu mets ton clignotant en freinant avec la ventilation en marche, le 25A risque de claquer et de te laisser dans le noir au milieu du tournant, voilà tout .
Bon, pour calmer le Tof et aussi sur le conseil avisé de mister TBird, une couche d'autojoint or de chaque côté de la rondelle, du frein filet sur le filetage de l'arbre, et voilà . En, fait (ce que je n'avais pas vu) ces cannelures ont un jeu démoniaque : même si ça ne bouge quasi pas une fois installé, on peut enfiler le yoke sur l'arbre comme papa dans maman, alors que selon TBird, on devrait avoir du mal à le mettre sans quelques coups de maillet. Et c'est vrai qu'en passant le doigt sur les cannelures du yoke, on sent bien que ça accroche au bout, là où ce n'est pas usé. En l'absence de fournisseur en neuf, aucun remède .
En gros, tu as ajouté un fusible sur le circuit principal, pour protéger toute l'installation ? Tu l'as mis directement sur le + batterie (hors câble de démarrage) ? Plutôt une bonne chose en tout cas Rien que l'éclairage (phares + codes + feux AR + loupiotes) c'est 15 à 20 A. Soit tu décides sagement de ne pas les utiliser avant d'avoir réparé et tu mets un fusible de 20A pour le reste. Soit tu vas les utiliser (roulage de nuit, appels de phare) et tu mets de toute façon un 40A sinon ça va claquer. En sachant que s'il passe (par exemple) 30A dans ton circuit foireux, ton fusible ne le protègera pas : le fusible (ce qui fond) ce sera alors le circuit... et en cas de court-circuit, 30A sous 12V ça chauffe fort Je dirais : utilise ton branchement pour ramener la voiture chez toi ou au garage épicétou. Un branchement provisoire, ça s'utilise... provisoirement . Quand tu demanderas sur le forum des adresses de loueurs de remorques (compatibles R21 ) pour amener un tas de tôle tout noir chez le Gitan, c'est que 40A c'était trop.
Le relais de démarreur (fixé sur la joue d'aile côté passager) a 4 bornes. - une grosse vers l'avant de la voiture reliée au + batterie - une grosse vers l'arrière reliée au démarreur - deux petites, une vers l'avant de la voiture et l'autre vers l'arrière. Pour faire tourner le démarreur (et le moteur), débrancher la cosse de la petite borne AV et relier cette borne à la grosse AV (ou au + batterie). Ne pas oublier de mettre la boîte sur N ou P, sinon la voiture t'écrase ou part dans le mur du fond...
Ah ils ne l'avaient pas changé ? J'ai pas tout suivi du coup
Des slicks sans autobloquant ? elle va tourner en rond cette voiture, engage-la plutôt en Nascar
Salut Steph Tu as vérifié que le jus arrive jusqu'aux bougies ? - prendre une bougie neuve (ou en déposer une), propre, avec le bon écartement (0,9 mm pour allumage à rupteurs, 1,5 mm pour allumage transistorisé) - la fixer à une bonne masse avec une pince-étau - contact mis, tenter de démarrer en la branchant successivement à tous les fils HT : fil de bobine, puis tous les fils de bougies. Il doit y avoir de belles étincelles régulières (beaucoup plus avec le fil de bobine que les autres). Ce qui est bien sur les Ford, c'est que le relais de démarreur sur l'aile permet de démarrer le moteur avec la tête sous le capot (pas besoin d'assistant). L'étape suivante, c'est la mesure des compressions (soupape qui ferme mal, moteur rincé, joint de culasse), et la dépose des cache-culbuteurs (poussoir grippé --> soupape qui reste ouverte ou fermée) Le pire ce ce puisse être, c'est la chaîne de distrib qui a sauté une dent, mais ça n'arrive pas deux fois de suite...
Bon, problème, ça suinte Pas par le joint spi, ni à sa lèvre, ni à son pourtour, mais par l'écrou central. La seule explication plausible est que l'huile passe par les cannelures de l'arbre. Verdict du forum du CLC : à l'origine, les cannelures de l'arbre et celles du yoke sont parfaitement appairées, le shop manual ne précise pas de précautions particulières au remontage. Mais avec les années ça prend du jeu, minime mais suffisant à perdre son étanchéité. D'ailleurs, quelques années plus tard, les cannelures sont délibérément montées "lâches" d'usine, et l'assemblage se fait avec un clinquant (à changer à chaque démontage) Remède --->>> Démonter, tout dégraisser et appliquer du joint silicone ("rtv sealant") sur les cannelures avant de remonter . Question : quelle sorte de joint silicone (qu'on trouve chez nous) ? du bleu, du rouge, du or, du vert à pois roses ?
Rouler en plaques US: oui, non, combien de temps?
Phil a répondu au sujet de Oregon-Classics dans Importation
C'est vrai, mais les Suisses n'ont pas de "phobie administrative" -
Tu as vérifié d'abord s'il y avait (ou non) des étincelles aux bougies ? Une vieille bougie (ou une que tu sors), fixée à une bonne masse par une pince-étau, tu y branches successivement tous les fils de bougie et tu essaies de démarrer avec quelqu'un sous le capot qui regarde et qui raconte.
La réponse est dans la question . homologation = réception aux Mines. CGC = dispense d'homologation, mais obligation de conformité à l'origine. La bonne question est : "en vigueur depuis quand ?". Ces textes ne sont pas (ou rarement) rétroactifs, autrement dit les "plans verticaux longitudinaux tangents" et autres "intensité lumineuse de 400 candelas" ne concernent pas une Delaunay-Belleville 1905 - et heureusement . Ma Cadillac a une CG française normale d'origine, et ne respecte à peu près aucun de ces éléments. De même pour ma Mustang, passée en RTI quand je l'ai importée (en CGN donc). Pour qu'elle soit déclarée "conforme au type d'origine", il a juste fallu y coller une paire de catadioptres, et remplacer les sealed beams par des optiques à veilleuses. Mais les clignos AR sont toujours rouges .
