Merci
Ils sont beaucoup plus achalandé question drag racing
J'ai renseigné ma config moteur. Ca rigole pas. Looker
Vehicle Information Year:
Make: Model: Weight: Transmission Type: Transmission Model: Rear Gear Ratio: Tire Height: Intended Use: Must this vehicle pass inspection?
Year: Manufacturer: Factory Cubic Inches: Current Cubic Inch: Compression Ratio: Piston Bore Diameter: Connecting Rod Length: Crankshaft Stroke: Desired RPM Range: to Ex. 1500 to 5500 Induction Intake Manifold Type: Ported: Cylinder Heads Manufacturer: Material: Head Runner Volume: Intake Valve Size: Exhaust Valve Size: Ported: Rocker Arm Ratio: Is Valvetrain Adjustable: Max Valve Lift Capacity: Fuel Delivery System Type: Fuel Injector or Carburetor Size: Fuel Type: Fuel Octane Rating: Power Adders Super Charger: If "Yes" above, the type is: , boost amount: psi Turbo Charger: If "Yes" above, number of turbos: , size: mm, boost amount: psi Nitrous: If "Yes" above, amount: H.P., number of stages: Current Setup Cam Manufacturer: Duration @ .050" Intake: Exhaust: Advertised Duration Intake: Exhaust: Valve Lift Intake: Exhaust: Lobe Separation: Intake Centerline: What area are you looking for improvements:
